Vraylight Material porblem
  • Vraylight Material porblem
    very simple scene just for clarification
    source light and 2 boxes plus vrayenvironment fog
    1st image a vraylight plane with texture and affect diffuse : 70 ( to get that fog effect without increasing the multiplier too much because it overburns the texture )
    2nd image trying to get same effect using vray light material using same texture ( direct illumination on )
    since their is no affect diffuse option in the vray light material i cant get similar result
    when i increase the light material multiplier too much the texture overburns
    is their a way to achieve this using vray light material ?
    anyone can help please ?
      Do you think you can post that scene? I'm not exactly sure how you have set up things. Is there a specific reason you have to use a VRayLightMtl material instead of a VRayLight?
        I prefer using it mainly for showing texture in viewport to see what am doing
        also vray lights has limitation in terms of shape
        vray light material is so much flexible i could add it and map it anywhere on any kind of complex model or even part of it
        blend it with other textures/ materials etc
        here is the file
        hope you can help me out
        thanks in advance
          There isn't a way to achieve the effect with the VRayLightMtl since it does not have that type of control as VRayLights. If shape is something of importance - use VRayMeshLights.
            You could use VrayLightMtl as the visible box and put your Vray Light in front of it set to `invisible` to create the fog so you can control each value in case of burnout ?
              hermit.crab thats really unfortunate
              anthonyh that is a solution for simple cases i think
              but a complex case where texture is animated along complex model would be impossible
                The VRayAtmosphere RE and the SelfIllumination RE should help you achieve what you want in post, without much trouble.
                You may need to create a few multi-matte REs to mask out the specific parts of a complex multi-material with lightselects on intricate geo, but if not the two layers will get you most of the way.
                Unless i have misunderstood you.
                Lele
                emanuele.lecchi@chaos.com
                Disclaimer:
                  ^Lele^ multiple problems here
                  that would be very hard to test before rendering final and i think would produce enormous noise that almost cant be fixed due to lack of information in dark pixels
                  Also if by any chance the fog is reflected/refracted on a surface that would be very hard to fix in post and will look very unrealistic
                    As a side note i tried increasing the generate gi value in the object's vray properties but that didnt affect the fog in any way which i didn't understand why
                    Isn't it supposed to affect it ?
                      Ok, so the setup is as follows:
                      VrayLightMtl with texture, set intensity as it's pleasing to the eye (let's say, 1.0).
                      That lightMtl becomes the child of a MtlWrapper, for which you set the GI generation multiplier to whatever works for the fog (say, 30).
                      Assign the mtlWrapper to the multi-sub slot, or the node you want to turn into a light, not the lightMtl.
                      Tick "scatter GI" in the environmentFog.
                      Lele
                      Disclaimer:
                        ^Lele^ thanks alot man never though of that
                        That solved the problem perfectly
                          ^Lele^ i can confirm this workaround doesn't work with vray next gpu
                            Mh, pity.
                            Could you write to support, ideally with a tiny sample scene set up attached (so it's quicker for them to find the issue.)?
                            Lele
                            Disclaimer:
