both denoiser change alpha channel
  • both denoiser change alpha channel
    hello,
    vray and nvidia change alpha channel as you can see at the pictures. default denoiser values
    ground object is vraymatte with shadow/alpha.
    known bug? any idea?
    thanks thomes
    render / vray / nvidia
    Click image for larger version  Name:	render.jpg Views:	1 Size:	149.2 KB ID:	1041766Click image for larger version  Name:	vraydenoiser.jpg Views:	1 Size:	146.1 KB ID:	1041765Click image for larger version  Name:	nvdenoiser.jpg Views:	1 Size:	120.5 KB ID:	1041764
    next update 2
    ...if someone is interested, here the max. reduced file
    denoiser.zip
    3dsmax 2019.3 vray next update2
      The alpha channel is denoised together with the RGB, which is the current default behavior. If you do not wish to denoise the alpha, generate the denoise elements only and use the 'vdenoise.exe' (...Chaos Group\V-Ray\3ds Max 2020\bin\) tool instead.
        don´t really understand the sense, but if its that way i have to pay much more attention.
        thanks Aleksandar
          We have a feature request to add an option for the denoising of the alpha channel so we will get to that.
            cool, very good idea...thanks vlado !
              Is this still on the to do list? Currently denoising the matte shadow is the only full proof way of getting a noise free shadow. But in doing so, it causes harsh edges between the ground shadow and rendered objects. On that note, is there any plans to improve the matte shadow noise? It is impossible to get it noise free without ridiculously high render settings.
              Thanks
                Thanks
                +1 I'm having a little trouble with the noise in the matte/shadow. If I use denoiser it creates weird edges near the rendered object.
                  Any news on this feature?
