Unhandled Exception error _VRay GPU
  • Unhandled Exception error _VRay GPU
    Hello
    I'm trying to render animation on Vray GPU and I'm getting these errors on random frames.
    It render perfectly fine on Vray Next CPU.
    Code:
    [2019/Jul/9|15:46:57] error: UNHANDLED EXCEPTION: Clearing global light manager.
    Last marker is at D:\cgrepo\vray\vray\src\vrayrenderer.cpp, line 4216: Preparing global light manager
    [2019/Jul/9|15:46:59] error: [VRayRTMax::Render] generated an exception. Aborting.
    [2019/Jul/9|15:46:59] [VRayRTMax::Render()] Cancelled before render
    [2019/Jul/9|15:46:59] [RTRenderSession::renderEnd] Calling endSequence()
    [2019/Jul/9|15:46:59] error: 5 error(s), 46 warning(s)
    [2019/Jul/9|15:46:59] ================================
    [2019/Jul/9|15:46:59] Broadcasting NOTIFY_POST_RENDER.
    [2019/Jul/9|16:00:45] Saving to file.
    [2019/Jul/9|16:00:45]   Saving distributed renderer.
    [2019/Jul/9|16:00:45]   Saving filter parameters.
    [2019/Jul/9|16:00:45] Saving done.
    [2019/Jul/9|16:25:56] Tiled texture cache set to 4000 MB
    [2019/Jul/9|16:25:56] error: Unrecoverable error happened during the last V-Ray GPU session. Restart 3ds Max to continue using V-Ray GPU.
    [2019/Jul/9|16:25:56] error: 1 error(s), 0 warning(s)
    [2019/Jul/9|16:25:56] ================================
    And if I try to render again it ask me to restart 3ds Max
    side note : why VRay log in 3ds max show only part of the log and not the full log , I would expect at least for the current render ..in this case I can't see the 5 error(s), 46 warning(s) that's mentioned in the message and I have to open the log text in notepad and search through it .
    Attached the full log ..let me know of you will need the scene too
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
    FYI: I just replied to you in the ticket you sent us.
    Miroslav Ivanov
    Chaos Cosmos
      Well received .Uploading the file now
      Thanks !
        Thanks. Got the scene and we're looking into it at the moment..
        Miroslav Ivanov
        Chaos Cosmos
