VRay Next Update 2 - DR Crashing on Windows 10 Master
  • VRay Next Update 2 - DR Crashing on Windows 10 Master
    I'm experiencing an issue with DR when one of the newer machines on Windows 10 picks up the job as a master. It will get to the denoising stage and then it'll crash. If an older machine on Windows 7 picks up the job as master, it will denoise and output the image without issue. For a bit of context, the DR job is sent to the network so one of the render nodes can pick up the job and act as master.
    What I found when comparing the vraylog on both the machines was that the newer machine couldn't load in the plugins.
    NEW MACHINE - WINDOWS 10
    Calling beginSequence().
    [2019/Jul/22|09:21:25] Loading plugins from "./vray_*.dll"
    [2019/Jul/22|09:21:25] loadLibrary(./vray_*.dll)
    [2019/Jul/22|09:21:25] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_dr1.dll"
    [2019/Jul/22|09:21:25] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_dr1.dll"
    [2019/Jul/22|09:21:25] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_gpu_common.dll"
    [2019/Jul/22|09:21:25] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_gpu_common.dll"
    [2019/Jul/22|09:21:25] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_http_client.dll"
    [2019/Jul/22|09:21:25] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_http_client.dll"
    [2019/Jul/22|09:21:25] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_optix_denoiser.dll"
    [2019/Jul/22|09:21:25] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_optix_denoiser.dll"
    [2019/Jul/22|09:21:25] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_telemetry.dll"
    [2019/Jul/22|09:21:25] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_telemetry.dll"
    [2019/Jul/22|09:21:25] 0 plugin(s) loaded successfully
    [2019/Jul/22|09:21:25] Finished loading plugins.
    On the older Windows 7 machine, it's able to load in the plugins successfully
    OLD MACHINE - WINDOWS 7
    [2019/Jul/19|17:43:21] Loading plugins from "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64/bin/plugins/vray_*.dll"
    [2019/Jul/19|17:43:21] loadLibrary(C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64/bin/plugins/vray_*.dll)
    [2019/Jul/19|17:43:21] Loading plugin "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_AAFilters.dll"
    [2019/Jul/19|17:43:21] Found plugin "FilterPoint"
    [2019/Jul/19|17:43:21] Found plugin "FilterMitNet"
    [2019/Jul/19|17:43:21] Found plugin "FilterCookVariable"
    [2019/Jul/19|17:43:21] Found plugin "FilterGaussian"
    [2019/Jul/19|17:43:21] Found plugin "FilterSinc"
    [2019/Jul/19|17:43:21] Found plugin "FilterCatmullRom"
    [2019/Jul/19|17:43:21] Found plugin "FilterLanczos"
    [2019/Jul/19|17:43:21] Found plugin "FilterTriangle"
    [2019/Jul/19|17:43:21] Found plugin "FilterBox"
    [2019/Jul/19|17:43:21] Found plugin "FilterArea"
    [2019/Jul/19|17:43:21] Plugin library "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_AAFilters.dll" loaded
    [2019/Jul/19|17:43:21] Loading plugin "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_ASGVISNode_ASGVIS.dll"
    [2019/Jul/19|17:43:21] Found plugin "ASGVISNode"
    [2019/Jul/19|17:43:21] Plugin library "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_ASGVISNode_ASGVIS.dll" loaded
    [2019/Jul/19|17:43:21] Loading plugin "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_BakeView.dll"
    [2019/Jul/19|17:43:21] Found plugin "BakeView"
    [2019/Jul/19|17:43:21] Plugin library "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_BakeView.dll" loaded
    [2019/Jul/19|17:43:21] Loading plugin "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_BitmapBuffer.dll"
    [2019/Jul/19|17:43:21] Found plugin "RawBitmapBuffer"
    [2019/Jul/19|17:43:21] Found plugin "BitmapBuffer"
    [2019/Jul/19|17:43:21] Plugin library "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_BitmapBuffer.dll" loaded
    [2019/Jul/19|17:43:21] Loading plugin "C:\Program Files\Chaos Group\V-Ray\3dsmax 2018 for x64\bin\plugins\vray_BRDFAL.dll"
    I've tried copying the plugins folder from the Windows 7 machine to the Windows 10 machine to no avail. The dlls listed under the Windows 10 machines are not present on both machines.
    Any help would be much appreciated
    Cheers
    Hello,
    It seems like the V-Ray installation on the Windows 10 machines somehow got messed up.
    The Win10 one has this line
    Code:
    and the Win7 one has the correct path:
    Code:
    Can you try reinstalling V-Ray on the Win 10 machine and see if it fixes the problem ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thanks Yavor.
      We'll have a look at reinstalling and will advise on the result.
      Cheers
        Hi Yavor,
        It doesn't look like it fixed the problem. We have downloaded the latest version of VRay (vray_adv_42001_max2018_x64) and have reinstalled it.
        The error still occurs below
        [2019/Jul/23|11:46:10] Loading plugins from "./vray_*.dll"
        [2019/Jul/23|11:46:10] loadLibrary(./vray_*.dll)
        [2019/Jul/23|11:46:10] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_dr1.dll"
        [2019/Jul/23|11:46:10] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_dr1.dll"
        [2019/Jul/23|11:46:10] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_gpu_common.dll"
        [2019/Jul/23|11:46:10] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_gpu_common.dll"
        [2019/Jul/23|11:46:10] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_http_client.dll"
        [2019/Jul/23|11:46:10] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_http_client.dll"
        [2019/Jul/23|11:46:10] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_optix_denoiser.dll"
        [2019/Jul/23|11:46:10] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_optix_denoiser.dll"
        [2019/Jul/23|11:46:10] Loading plugin "C:\Program Files\Autodesk\3ds Max 2018\vray_telemetry.dll"
        [2019/Jul/23|11:46:10] error: Error getting library description "C:\Program Files\Autodesk\3ds Max 2018\vray_telemetry.dll"
        [2019/Jul/23|11:46:10] 0 plugin(s) loaded successfully
        I've tried uninstalling VRay manually and reinstalling it but the error still remains.
          Hm - in that case:
          1. It would probably be easiest if you can you drop an email to our support (support at chaosgroup.com) - they can arrange a remote session and see why the installer fails to set the proper paths.
          2. Alternatively you can try the following:
            1. Uninstall V-Ray again
            2. After the uninstall - check for any remaining environment variables related to V-Ray for 3ds Max 2018 like this:
ID:	1043439 then Click image for larger version
ID:	1043440and then delete those : Click image for larger version
ID:	1043441also if you see any other variable related to V-Ray for 3ds Max 2018 in both fields - delete it. The installer should set them properly the next time.
            3. Install again (using the installer you already downloaded). During the installation check this screen:
ID:	1043442The path for "V-Ray for 3ds Max additional files" should be like the one in the screenshot. If it is not - you can change it by clicking the Customize button.
          Hope that helps and sorry for the inconvenience.
          Yavor Rubenov
            Thanks for the reply, Yavor. We'll give your suggestion a go and if the problem persists, I'll contact support as suggested.
            Appreciate your help.
            Cheers
