animation prepass with negative "active time segment" does not render light solution
  • animation prepass with negative "active time segment" does not render light solution
    hello,
    if you set the active time segment to begin at frame -2 at animation prepass, the whole sequence does not render correct light solution.if you set the active time segment to begin at 0 and render "range" from -2 to... it works.
    thomes
    vraxnext update2 / max2019.3 update
    Would it be possible to send a scene to philip.shounev@chaosgroup.com to take a closer look?
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      mail sent. thanks for looking into
      thomes
        Hi again,
        It seems that the saved .vrmap files are empty when the active time segment starts with a negative frame number and "Use camera path" option is enabled. A workaround for that would be if the active time segment begins at 0 and the render range - from -2, as you have mentioned in your previous post.
        Best,
        Philip
        Philip Shounev
        QA department
        Chaos
          ...for sure they are empty... there is no visible rendering of the passes
            Thank you for your feedback. I've logged that in our bug tracking system under VMAX-8901.
            Philip Shounev
            QA department
            Chaos
