V-Ray Clipper and PhoenixFD Liquid Sim Splashes Rendering Black
  • V-Ray Clipper and PhoenixFD Liquid Sim Splashes Rendering Black
    I'm unable to post a new topic or respond in the PhoenixFD sub forums for some reason so I am posting this here.
    I am trying to render the splashes from my liquid simulation with a V-Ray clipper mesh, when the splashes are intersected by the clipper mesh they are currently rendering black. Is there a work around for this or is this just not feasible?
    I tried changing the material to a solid white for the V-Ray clipper and I get similar results, The liquid in the middle when intersected render out with the V-Ray Clipper material but the splashes won't.
    Also for the forum mods do you know why I can't post in the PhoenixFD sub forum? Thanks!
      Hey,
      Thanks for reporting that, I have logged this as a bug in our system. Looks like this is not working correctly for the Spalshes and Bubbles modes.
      For the Mist you can use Fog or Point mode - just make sure that you turn Geometry Mode on for the Particle Shader.
      As for the Phoenix FD forum access - send over and email to the support guys and they will help you out.
      Cheers,
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        As a workaround to cut the particles you can use the Cutter Geometry option - you can find more about it here - https://docs.chaosgroup.com/display/...er+%7C+PHXFoam
        Georgi Zhekov
        Chaos
          Thank you Georgi I used that work around for the splashes and it seems to be working as expected now after making the cutter geometry non renderable.
            Awesome, I'm glad it's working now.
            Cheers,
            Georgi Zhekov
            Chaos
