VrayReflection Element Not Rendering
  • VrayReflection Element Not Rendering
    Due to camera shutter efficiency not working in Next GPU, I switched over to CPU. The render looks significantly better in the beauty pass, but for some reason the reflections aren't being rendered to the Reflection element. They appear correctly in the beauty pass however.
    From the docs: "Since V-Ray Next Update 1, some of the render elements are rendered differently than before. The Lighting render element now contains all direct diffuse illumination and the GI element contains all indirect diffuse illumination. Similarly, all direct reflections of lights now go to the Specular element and all indirect reflections go to the Reflection element."
    https://docs.chaosgroup.com/display/...ender+Elements
      That explains it. Thank you.
      Although a bit confusing that Next GPU hasn't also changed over.
        The consistent elements are always on in V-Ray Next GPU (since Update 1.1, I believe)
        Miroslav Ivanov
        Chaos Cosmos
