I'm having a strange issue where a tyMesher mesh (from tyFlow) renders fine when motion blur is enabled, until I apply a modifier to it...at which point a crash immediately occurs during the Light Cache phase of rendering.
Vray 3.60.04, attached is the minidump, as well as the scene file and cache. Hit render and it should crash (you may need to point the tyCache to the included cache files first). If you get a tyFlow version warning when you open the file, you can ignore it. You should also be able to ignore any missing map warnings, as the crash is not shader dependent and happens even if a simple Standard material is applied.
