Reflection Hell
  • Reflection Hell
    My last three exterior jobs, I think since the latest V-Ray, my reflections have been unusable. I am using an HDRI and V-Ray Sun.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    You mean the VRayReflection render element? Can you show me what the main RGB looks like?
      Yes, of course. This is straight out of the VFB.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I take it the reflection element you've posted above is after you've boosted it up a lot in post? Or is that the raw reflection pass? It looks like the reflection contributes very little those pixels so vray isn't going to make much effort there. If you have a look at your reflection filter element also, it's probably very very dark in those areas. Vray is going to sample based on the final RGB only so it won't go further than it needs to. What's your noise threshold in your aa settings?
          does kinda look like a raw reflection pass
          www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
            No, that is a screen grab of the VFB and not zoomed in. The RAW Reflection is just as bad.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Here are the reflection and raw reflections saved from the VFB. Above was a screengrab.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                The light select of the HDRI is also not usable
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  All my V-Ray settings are the default and I am using bucket rendering.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I bet there is some kind of light or something causing this...
                    Dmitry Vinnik
                    Silhouette Images Inc.
                    ShowReel:
                      denoised renderelement ?
                        even knowing which engine you're using would be beneficial.
                        CPU or GPU?
                        Could we get the scene?
                        Lele
                        emanuele.lecchi@chaos.com
                        Disclaimer:
                          Second, I've never seen a noisy element like this. You should try and render only with a vray sun, and see if it's still like that.
                          A.
                          www.digitaltwins.be
                            Stuff like thing often happens when there are some old and unsupported standard materials or maps like raytrace are hidden in the scene.
                            My bet is it doesn't happen with a semimatte grey override material.
                            • #15
                              CPU and I"ll try just V-Ray Sun/Sky and a material override.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
