Problem with Light Cache - HashMap
  • Problem with Light Cache - HashMap
    I was getting a light circle above the spotlights with a white (190 white) material until I switch to the old KD tree light cache or change the material to a darker one.
    I used reset x-form on the spotlights and even put a cup-like object into the spots, to be sure there is a closed object inside of the spots, but nothing worked except switching to the KD tree.
    What is going wrong?
    https://www.instagram.com/bildform.de/
    I couldn't reproduce those artifacts in a new scene. Would it be possible to send over a scene to philip.shounev@chaosgroup.com for a closer look ?
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Yup, it would be best to send a scene to Philip to check out.
        I have done that,
        The max version is 2020.1 and the newest V-Ray.
        The original object for the spotlight is an imported step-file.
        Other than that, there ist nothing special about it.
          Ok then. Can you tell me which V-Ray version you have now (as shown in the About rollout)?
            It is 4.20.01.00001
              Great, thanks! Looking into it.
                Off topic: I do not know much about math, but is this helpful for V-ray? I just read about it.
                https://www.quantamagazine.org/mathe...ages-20190725/
                  It’s an interesting read, but doesn’t help much for the problems that we have to deal with
                    Any news about what went wrong?
                      Yes, I'm working on a fix now. For the moment you can move the disc light to be just outside the light fixture and it will be fine.
                        Thank you for the tip. I should have done that, but it is just to obvious...
