Alsurface shader don't receive caustics
  • Alsurface shader don't receive caustics
    so as the title says, Alsurface shader don't receive caustics . They won't show up if you have alsurface with SSS on ( I don't know if the sss is off, I did not tested that ) so let's say you have a glass object in front of and alsurface object and there is caustics casting from the refractive object onto the alsurface, it will not receive them and will look very dark while the sss2 it worked.
    Hello! It seems to work here in a simple scene with VRayALSurfaceMtl with sss mix values <1 Click image for larger version
    Tanya Todorova
    QA
      First of all, sss mix should be 1. Also, try to use 2 sphere superposed, like for an eye let's say, and the external part beeing transparent and you uncheck affect shadow and put raytraceon of course. you will get problem.. I guess I will have to post a scene for that too
        You are right - it's not working when sss mix is set to 1 and I've log it in our bug-tracking system under VMAX-9115. A scene would be very helpful. You can send it over to tanya.todorova@chaosgroup.com. Thanks!
        Best,
        Tanya
        Tanya Todorova
        QA
          What's obvious to you may not be, and often is not, obvious to everyone else.
          A sample to reproduce an issue should be considered a firm request from our part, one to skip only if it's impossible to narrow the problem down (f.e., random crashes or hangs non scene-dependent.For which one should submit a minidump, if at all possible.).
          Lele
          emanuele.lecchi@chaos.com
          Disclaimer:
            Its like Luc posted, this shader does not support recieve caustics when you go up to sss mix 1. Reading Lucs postings recently i feel we ran in the same troubles more and more..
              pretty advanced scene :
                You will notice the scene is now redundant.
                I am sure your renders won't be all that different with mix at 0.99, however.
                See if you can live with that while it gets fixed.
                Lele
                Disclaimer:
