error message "calling evalworldstate" with particle flow
  • error message "calling evalworldstate" with particle flow
    hi,
    can render a scene with 15 million " particle flow" particles (at 64gb ram), but when i additionally use "mapping object" vray crashes with this error message :calling evalworldstate()
    what can i do?
    thanks for help
    thomes
    3dsmax 2019.3 vray next update2 64gb ram
    Hello,
    Thanks for sharing this. Indeed it seems to happen when adding a mapping object operator in the particle viewer, so I've logged it in our bug tracker under VMAX-9121. As a workaround you could try turning off the mapping object and then add the particles to VRayInstancer.
    Best,
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Originally posted by Philip Shounev View Post
      Hello,
      Best,
      Philip
      thanks philip, but with "mapping object" my particles get the mapping coordinates of the emitter object, this behaviour i can´t get with vrayinstancer...there all particles get the same mapping... or am i wrong
      emitterobject:
      this is vrayinstancer
      Click image for larger version  Name:	vrayinstancer.jpg Views:	1 Size:	104.3 KB ID:	1049191
      this is mappingobject
      Click image for larger version  Name:	pf.jpg Views:	1 Size:	197.2 KB ID:	1049190
        Hi again,
        It turned out that the mapping object operator crash is related to some extend to what is set in the "Mapping Channels" section, so you could try switching to mapping channel 1 only. If that doesn't resolve the problem, there's another way to solve it with the help of two particle flow sources. Both of them should have material static and position object operators. The idea is to use a Multi / Sub material assigned to the material static operators which have an option to set Material IDs. When adding a position object operator, enable " Density by material / Grayscale / Use Sub-material " option. There you can set another material ID which should be used by the particles for distribution. Thus the particles will be emitted from certain areas. For better representation I'm attaching a couple of screenshots showing the particle viewer setup:
ID:	1049279Click image for larger version
        Philip
        Philip Shounev
        QA department
        Chaos
          thanks for help philip ! ... very cool idea. i could try this, but i have a multisub material with about i think 15 materials or so... the pictures with the black red sphere are only for demonstration purposes. anyway... i had a look and i have mapping channels 1 ticked. and further i got about 55 frames rendered and after that all machines involved brought up the error message "calling evalworldstate()". so something must happen then to crash them...
          Click image for larger version  Name:	MC1b.jpg Views:	2 Size:	400.1 KB ID:	1049296
            Thank you for your feedback. A more thorough investigation might be needed, so I've forwarded the additional information about this case to our developers.
            Philip Shounev
            QA department
            Chaos
              Our developers have resolved an error that appears in a similar scenario. You can download the latest stable from our nightly builds:
              https://nightlies.chaosgroup.com/mai...ble/stable_4.3
              Philip Shounev
              QA department
              Chaos
