When using EXR's as textures, the following errors will pop up:
error: Error loading texture tile (1, 1) from level 5, file "\\servername\folder\texture_name.exr" : [EXR TileLoaderParams::loadTile] OpenEXR error: Error reading pixel data from image file "\\servername\folder\texture_name.exr" . EXR file read failed ([PfileStream::Read] (59) An unexpected error occured. )
The following are band-aid fixes I've found
Restarting Max
Increasing the cache size in the tiled texture cache. (though our one animator says that )
I haven't had any luck with "Clear Cache on render end" I thought that it might be caused by the exr's getting "locked" as unlike other texture formats we have had problems overwriting exr's whenever max is active.
Any insight would be greatly appreciate
-Josh
Restarting Max
-Josh
