Dome light visibility affecting reflect/refract
  • Dome light visibility affecting reflect/refract
    I'm at my wit's end here! The only difference between the two snapshots below is that the dome is visible in the top, and set invisible in the bottom. There's a window in the scene, so it has to stay invisible, but it should still be seen through the window through reflection/refraction.
    Any thoughts?
    Turning on the invisibility of the dome light affects the light seen directly by the camera or through refractions (which I think is the cause of the difference). You may bypass this by setting a reflection/refraction environment override (V-Ray>Environment>Reflection/refraction environment).
