Glare networkrendering
  • Glare networkrendering
    I have the problem that the glare element is not generated on network slaves!
    I have left the Glare options open (Frame buffer) and when I look at the renderslaves the bloom and glare option is off, it is only on at my workstation!
    All my settings are not set on the render slaves!
    Max 2019 last Vray Next Version!
    I think it, worked fine with the last version of vray!
    www.dk-vision.de
    I can't seem to replicate the issue on a simple scene with Backburner. Are you certain the slaves have the same V-Ray version installed as in your workstation? Does it happen on a specific scene? Could you provide a bit more information about the issue, the steps to reproduce it, the render manager used, the specific V-Ray build version?
      Problem solved! I have reinstalled vray on every slaves!
      It was the same version, as I had no problem two weeks ago, and didn't install a new version.
      Don't know what was broken!
      Thanks for the Help
      www.dk-vision.de
