I've just started using vray again after many years (employer finally purchased a current copy for me) and have some issues overcoming the differences between my original scenes and the new versions of max+vray. I don't even know what the originals were done in anymore - they were ancient though, so version1.5 most likely. This is bringing back memories though of the original, extremely steep learning curve i remember from years ago....and the issues. Here is a short list of pretty vague issues i'm having:
1. i've adjusted an old scene to overcome some noise and other issues and this rendering time is balooning out to 20 hours (was 4 hours)
2. I've noticed several of the old materials either look more shiney or desaturated than before - which has forced me to look for new materials. this metallic variable and other changes are a bit confusing to me?
3. My window frames, car paint and shadows cast by trees on the foreground all look quite grainy to me, which led me to change some settings - not sure if its the max subdivs or noise threshold on the image sampler? it all operates very differently now to what i remember
4. in the past my interior lights would need a multiplier of say 50-100 but now i'm having to set them to 1000 just to be visible, and i still cant see my IES downlights. surely your standardy light brightness should be around 1x ?
5. I've had to set a separate Vray sky with different settings to my environment maps because it was rendering out extremely bright white - previously this was a nice blue gradient. shouldnt it generate a suitable background map linked to this? it seems to work quite differently now
Honestly i'm feeling a bit demoralised - thinking the return would lead to quicker images and a bit easier to negotiate, i find myself confused with the old job setups and converting to a current setup. Maybe i'd be better off starting the lighting and camera's from scratch with a template?
I know it's just a part of the learning process but i was getting better images out of twinmotion which is probably the easiest bit of software i've ever used. I know there is a massive theoretical difference in quality and that it's going to be harder.
Or am i just an idiot?. Maybe vray needs an idiot mode for architects and people who have not touched vray for many years
. Ideally i would like this kind of scenario: "Here is my crappy ArchiCAD model with excessive geomoetry....*click button*, automatically good setup with quick renders
Another thing I REALLY loved about twinmotion - the direct link to the model meant i could set up my rendering and it would link to archiCAD and update the geomoetry with one click. At the moment i have to export the amended geometry as a separate 3ds file, bring it in and attempt to delete the obsolete geometry manually.
vray Next for idiots please
