Next Update 3: Crash after canceling or finishing a render
  • Next Update 3: Crash after canceling or finishing a render
    Hey guys,
    after Update 3 we get a lot of instant crashes after canceling or finishing a render. As soon as you hit Esc key, Max crashes. Anyone with similar experiences?
    Have a similar problem since some weeks, may be that is in relation to yours. When I hit the render button while interactive rendering is active in the VFB window MAX hangs, but I can save the changes. I´m not able to close the VFB or the render progress window, but I´m able to close for example the material browser or I can save and quit MAX. Is your interactive rendering active when you start to render?
    Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
      No. This is production rendering in bucket mode. We have this issue on 3 identical workstations in different scenes.
        My problem was also with production renderimg. But I didnt stop interactive rendering before I hitted the render button for production rendering. When I stop interactive renderung in the VFB before that all works fine.
          I can definately say that the IPR was stopped before starting production render.
            I created two dump files after a crash. Where should I send them to?
              You can attach them here or send them to support (support at chaosgroup.com).
              Yavor Rubenov
              V-Ray for 3ds Max developer
                Okay, here they are. I hope a solution can be found because right now Update 3 is too unstable to use in production.
                3dsMax_Minidumps.zip
                  Thanks for the dumps - not much info so far - it seems something crashes inside the Max bitmap manager. Could you try to convert any bitmaps to VRayHDRI and see if anything changes while we are investigating.
                  Yavor Rubenov
                    This could make sense, because sometimes we get a crash while browsing out material library. While the swatches calculate the preview image, we get the crash.
                      I can not confirm that converting to VrayHDRI is a solution to that problem.
                        Crash dump after conversion to VrayHDRI.
                        3dsmax_minidump03.zip
                          Thanks for the heads-up here guys. I have a Monday deadline that this could have quite dramatically screwed with if I hadn't had chance to test it,
                          which I will do tomorrow and see if it is replicable.
                            The new dump still seems to be somewhere in the Max bitmap manager - something related to the view port background image.
                            We are also still trying to find what causes it.
                            Yavor Rubenov
                            • #15
                              I checked the viewport background files, nothing extraordinary. It is an 8bit Jpeg, RGB Color. We had issues with CMYK files in the past, but it is none of these issues.
