ColorCorrect plugin can cause shading problems
  • ColorCorrect plugin can cause shading problems
    The ColorCorrect plugin can cause shading problems with VRay (red dots, bright spots etc). This seems to be because of bugs in the ColorCorrect plugin itself and is not a VRay problem specifically.
    This was tested with version 3.0.3.6 of ColorCorrect.
    thats the most painful post I've read in a while.. is there any hope of a workaround or fix?
    Dave Buchhofer. // Vsaiwrk
      Well, I've sent an email to Cuneyt Ozdas - if there is anything that can be done, he is the one to do it...
        Darn, CC is one of the most useful plugins for Max.
        Richard De Souza
        www.themanoeuvre.com
          hmm, I've been using CC w/ vray on different projects w/ lot of maps affected by CC, and so far I haven't had any issues........but thanks for the warning....hope things will keep going the way they are (crossing my fingers)
          paul.
            I suppose it may be happening only with HDR images, but I'm not sure...
              You can try this: Take a standard material and put a noise map in the diffuse slot. Then two colorcorrect nodes on top of the noise. The lower one with contrast 400 and the colorcorrect on top with gamma >1.
              Standard material
              diffuse:
              colorcorrect (Gamma >1)
              +--->colorcorrect(Contrast 400)
              +----->Noise
              And it's red (also with max scanline renderer).
              Dieter
              visit my developer blog
                I believe this is the second time an issue between VRay and CC has occurred, its so annoying specially as i use it alot.
                  color correct is strange...it looks like a great plugin but it doesn't work as i expect it.
                  especially the hue/saturation controls are confusing.
                  Marc Lorenz
                  ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
                  www.marclorenz.com
                  www.facebook.com/marclorenzvisualization
                    Is this CC issue solved in the current Vray RC2 Version ?
                    Artur Leao | Co-Founder / Project Manager
                    You can do it! VFX
                    Porto/Lisbon - Portugal
                    http://www.ycdivfx.com
                      IT is CC that is broke, not VRay . Basically it works, just if you try to tweak a map too far you can have issues.
                      Eric Boer
                      Dev
                        Yeah, one time I tried to turn a map of reddish tuna into a green garnish with color correct... apparently I'd gone too far, overbrights were everyyywhere.
                        Another note about using CC with HDRI maps -- I've had problems, but have successfully been able to hue-shift them using HSL space. I've found that if I have RGB space ON, even with no adjustments made, VRay freaks out and takes a loonnggg looongg time to calculate the HDRI.
                        Shaun
                        ShaunDon
                          also, the saturation does not work at all.
                            I downloaded the latest build from Cuney Tozdas' site, no guarantees, but it past the test given on this thread for non HDRI images...
                            http://www.cuneytozdas.com/software/3dsmax/
                            ColorCorrect_v3.4.86.9_x86
                            Max 9, V-ray 1.50.00
                            Keith R Morrison
                            focus360, Inc.
                            Win10, 3DS Max 2021, V-ray 5.2.3
                            • #15
                              I've been using it for a while now, with both Max 9 and Max 2008 in combination with VRay 1.50.00 and 1.50.17 but haven't had any problems. So I guess it has been fixed over the past three years :P
                              www.artbyarjan.com - Online portfolio (temporarily offline)
                              @home:
                              / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
                              / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
                              @work:
                              / Intel Core2Quad Q9450 @ 2.66Ghz /
                              Nvidia Quadro FX 3700 / 8Gb Ram /
                              / Vista Bussines x64 /
