VRayHDRI map issues with "Start Frame"
  • VRayHDRI map issues with "Start Frame"
    is it a known issue that VrayNext ignores the "Start Frame" Value under "Time" when I load an image sequence into the VRayHDRI map? When I am dragging the timeslider I see the material editor preview moving. When I am changing the Start Frame nothing is happening. I am using Max 2020, Vray Next Update 2.1
    I checked with Max2019 and Vray 3.6: it worked. There is a minor display bug but Start Frame is working as expected.
    Thanks!
    Daniel
    Thanks for the report. It seems the viewport/material swatch is not updated properly when changing the Starting frame parameter of the VRayHDRI. Logging it in our system (Bug-tracker id: VMAX-9481) for our developers to look into.
