Clear "seperate render channels" file path
  • Clear "seperate render channels" file path
    Hello, Is there a way to clear the path field for render channels? I know that when the "separate render channels" checkbox is off it has no effect, but I need to clear it anyway.
    Thanks,
    Oren
    Hello,
    You can use MAXScript like this:
    Code:
    renderers.current.output_splitbitmap=undefined
    this will clear the Bitmap object
    and then:
    Code:
    renderers.current.output_splitfilename=""
    will clear the filename text itself
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thanks, Works Great!
        Welcome
        Yavor Rubenov
