Texture looks washed out when looking from an angle
  • Texture looks washed out when looking from an angle
    Hi
    I'm making some furniture renders but the fabric material (made using a simple falloff map) seems washed out on the top side. Is there anyway to avoid this?
    I'm using a uvw map modifier (set to box)
    AMD Ryzen Threadripper 2950X 16-core CPU @ 3.50GHz 64GB RAM Vray Next 3DS MAX 2020
    Have you tried turning texture filtering off?
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
      Somewhat better, Thank
        Are you using VrayHDRI for your texture? Might want to give it a try and put the filtering to sharp isotropic.
        A.
        www.digitaltwins.be
