Saved 32-bit EXR's with LUT enabled in VFB act as 8-bit precision images instead
  • Saved 32-bit EXR's with LUT enabled in VFB act as 8-bit precision images instead
    I'm not sure if this is a bug or the way it should be, hence my question. When I have a LUT loaded and enabled in the VFB, saving EXR's with 32-bit precision don't retain the 32-bit precision, but act as if they are ordinary 8-bit images such as JPG. As soon as I disable LUT in VFB, saved 32-bit EXR images act as 32-bit precision again. I've tested this with Affinity Photo 1.8.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    My understanding is that applying a LUT anywhere will destroy the high dynamic range information and remap it to a 0-1 interval.
    Interesting fact : try doing the opposite of what you did : save the raw EXR from VFB without LUT, then apply the LUT in affinity Photo. You'll notice that the image is now 8 bit too.
    mekene
      Interesting. Then why does using a LUT in the VFB not destroy the dynamic range?
      Aleksandar Mitov
      96GB DDR5
        What you mean is : in the VFB, even with a LUT applied, you can adjust the color corrections controls while still retaining the full dynamic range, right ?
        I guess this is because the VFB internally acts as an light compositing app : it loads the RAW 32 bit image, applies all colors corrections in 32 bit and then applies the LUT as a last step.
        This is how you would do it in any compositing app, and why there is no reason to bake any correction into the raw 32 bit output.
        mekene
          Yes, that's what I meant. Thanks for the explanation! I'll see if I can add the LUT in my compositing app (Affinity Photo) and get the same result.
          Aleksandar Mitov
          96GB DDR5
