Bug 04. Vray 1.46.15 Light Cache render 50% time CPU
  • Bug 04. Vray 1.46.15 Light Cache render 50% time CPU
    Max 6 + SP1. Win2000 SP4. HT-on.
    Render use full time CPU - 100%
    Light Cache prepass use only 50% time CPU
    Vlado this is a bug or not?
    What are you light cache settings?
      Subdivs 1500
      Sample size 50cm
      Scale world
      store DL -off
      Show calc.phase -on
      Pre filter -on 10
      filter fixed
      filter size 200
      number of passes 1
      use light cache for glossy -on
      single frame
        Try to put "number of passes" to 2 and see what happens.
        Setting the value to the number of processors (HT = 2) normally works best.
        Sascha Geddert
        www.geddart.de
          Tranks!
            Each light cache pass is assigned to a single thread; so if you set the number of passes to 1, you will only get one thread working on the light cache.
