bitmap loading to max
  • bitmap loading to max
    Hi!
    what is the best way to load bitmap to 3ds max?
    I use bitmap map and I get this strange result.
    All the colors are changed.
    See attached pic.
    Seems like there is something the matter with the color spaces. Check if your 3ds max native gamma settings (Customize>Preferences>Gamma and LUT) are set to 2.2. You can also load the image through the VRayHDRI node, in which there is a color space parameter for additional control.
      Hi!
      thank oyu for your response but setting in LUT/Gamma are set to 2,2.
        I have found a problem.
        Bitmap was saved as cmyk. After resave as rgb, everything was OK.
        Thank you Aleksandar for answers.
