green spots
  • green spots
    Why am i getting green spots. All materials are vray materials and are Blinn.
    Im useing light cache and QMC.
    try using iradiance map and light cache. see if that helps
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      jacksc02 i am useing light cache and IR Map. Still get the splotches
        have you tried putting a global override material on everything to see if its a geometry problem?
        What is your secondary rays bias set to?
        Chris Jackson
        Shiftmedia
          here is a image with the vray overide no green splotches.
            Here is one with materials and glossy turned off
            im still getting green splotches.
            secondary ray bias set to default of 0.0
              looks like a problem with the curved panel material. try putting a flat white material on it
              Chris Jackson
              Shiftmedia
                now thier red spots
                  killed all materials associated with the panels and re-created them...........red splotches again. All geometry associated with them have uvw map's on them.
                    what version of vray are you using?
                    Chris Jackson
                    Shiftmedia
                      How are you lighting the scene ? ..
                      Natty
                      http://www.rendertime.co.uk
                        gadzooks, if you want, you can send me an email - I can get you a newer build that will most likely solve your problem.
                          jacksc02 im running the current build.
                          natty im using vraylights in all the windows with a direct light for the sun.
                          useing QMC 1st bounce Light Cache for the second bounce.
                          Vlado i sent you my email to your PM account
                            These i believe are related to glossy effects and even when you are using blinn instead of ward, i hope its fixed in the new release. If you play around with your glossiness and subdiv settings you might be able to get rid of them but not with the same results you had in mind.
