I wanted to register Vray spawner as a service on my render slave, so I went to Start Menu > Vray Next for 3ds Max 2020 > Register as a service the V-ray spawner for 3ds Max 2020 (run as administrator). It asked me for user and password which I typed in. So far so good. I then started a render on one of the workstations using that machine as a render slave. It joined the rendering process, but it rendered everything with grey materials. Why is that and how do I fix it?
Vray spawner as a service renders with grey materials
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
3ds Max 2023.2.2 + Vray 6 Update 2.1
AMD Ryzen 9 9950X 16-core
64GB DDR5
GeForce RTX 3090 24GB + GPU Driver 551.86Tags: None
The assets are on a mapped network drive. The physical drive resides in one of the workstations that is also used for rendering. No, I haven't checked the "transfer missing assets" option. Is enabling this mandatory when using Vray Spawner as a service?
And another question. Can I use two Vray Spawners simultaneously in case I want to render with both Vray Next and Vray 5 beta with that render slave (not at the same time of course)? The render slave is unattended most of the time so I don't want to always manually remote desktop to it to start/stop spawners depending on the version of Vray I want to render with. Ideally, I want to just hit render and the slave to decide which spawner to use.Last edited by Alex_M; 09-06-2020, 07:54 AM.Aleksandar Mitov
64GB DDR5
Check if the "transfer missing assets" option makes a difference. Otherwise, does it happen in a particular scene? Could you send it to support@chaosgroup.com so we can take a look?
You can have two VRaySpawners running simultaneously with different versions of the host platform. For example, 3ds max 2020 will have V-Ray NEXT installed on both the slave and the workstation, whilst 3ds Max 2021 has V-Ray 5 installed. Activate both VRaySpawner versions and send jobs through the respective 3ds Max/V-Ray version.
Originally posted by Alex_M View PostThe assets are on a mapped network drive. The physical drive resides in one of the workstations that is also used for rendering. No, I haven't checked the "transfer missing assets" option. Is enabling this mandatory when using Vray Spawner as a service?
The "Transfer missing assets" option will do too, but it's slower compared to accessing the assets directly from the share. See https://docs.chaosgroup.com/display/...deringSettings
Originally posted by Alex_M View PostAnd another question. Can I use two Vray Spawners simultaneously in case I want to render with both Vray Next and Vray 5 beta with that render slave (not at the same time of course)? The render slave is unattended most of the time so I don't want to always manually remote desktop to it to start/stop spawners depending on the version of Vray I want to render with. Ideally, I want to just hit render and the slave to decide which spawner to use.
E.g. - if you use V-Ray for 3dsMax 2020 and 3dsMax 2021.
- for 2020 register it on the default port 20204 -> Start Menu\Programs\V-Ray 5 for 3ds Max 2020\Distributed rendering\Register as a service the V-Ray spawner for 3ds Max 2020"
same thing command - line
Code:"C:\Program Files\Autodesk\3ds Max 2020\vrayspawner2020.exe" -service
Code:sc create "VRaySpawner 2021_20209" DisplayName="VRaySpawner 2021_20209" binPath="C:\Program Files\Autodesk\3ds Max 2021\vrayspawner2021.exe -port=20209"
After that - in DR settings - for 3dsMax 2021 change the default port 20204 to 20209 before submitting a job.
Ivan Slavchev
SysOps
Chaos Group
