Vray 5 Lens effects when on, CC are not being saved correctly
  • Vray 5 Lens effects when on, CC are not being saved correctly
    If LensFX are off, and we have several CC layers (white balance, filmic, etc.) and when saving an EXR with "save vfb CC", they are correctly saved in the default EXR layer.
    If LensFX are on, all those CC layers above are not saved in the default EXR layer, but instead in the "EffectsResult" layer together with the LensFX and RGB image (which shouldn't happen, instead, the CC layers should be saved in the default layer, and the "EffectsResult" should be only with the LensFX on top)
    This was the normal behaviour in Vray Next, and is what should logically happen.
    Let me know if this is a known bug, or if you need a scene.
    Hello,
    Unlike VFB1 in VFB2 LensFX, the denoiser and all the color corrections are part of one structure - the layers tree. That is why they are all saved in one location.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
