Okay, I'm using a material with a couple of OSL shaders being used to distort UVs for parallax mapping, and I'm running into some strange behavior/bugs.
The first issue - using a 2nd UV channel in the material. It works in CPU:
![Click image for larger version
Name: Annotation 2020-06-22 094833.jpg
But not in GPU. In GPU mode I get something that looks like it's using some sort of "default" channel mapping?
Name: Annotation 2020-06-22 100624.jpg
When I remove the 2nd channel usage, it goes back to using the 1st channel, but you get obvious stamping of the interiors:
Name: Annotation 2020-06-22 100946.jpg
I'd really like access to that 2nd channel.
The second issue is that Normal mapping is not working in RTX mode. Here's just the normal and opacity map in CPU:
Name: Annotation 2020-06-22 095149.jpg
Nice shading, fits the normals, works great.
Now, same shader in GPU/RTX:
Name: Annotation 2020-06-22 095722.jpg
Nothing.
Here are my test scenes.
GPU UV#1 (normals broken):
https://drive.google.com/file/d/1n_c...ew?usp=sharing
GPU UV#2 (normals broken, UVs broken):
https://drive.google.com/file/d/1-CL...ew?usp=sharing
CPU UV#2 (normals ok):
https://drive.google.com/file/d/1RQY...ew?usp=sharing
I'm also seeing massive progressive slowdown in rendering these tests - as described here:
https://forums.chaosgroup.com/forum/...n-rtx-gpu-mode
Please help.![big grin](https://forums.chaos.com/core/images/smilies/biggrin.gif)
Thanks!
Nothing.
Please help.
Thanks!
