I'm finding the saving of renderpasses a bit inconsistent in it's logic. My normal process is as follows:
V-Ray Next:
- Set the exposure (mostly lowering burn)
- Save passes incl. the effect result with denoiser on
- Turn on lens effects and save out the effects result pass with the glare/bloom. (I want to use is separate from the denoised version)
* I could only get a denoised version incl glare/bloom if the lens effects setting was turned on prior to opening the vrimg. If turned on after opening vrimg I would lose the denoised version and only have the glare/bloom on the original "noisy" rgb pass.
But anyway, moving on to 5 I'm finding the following issues/design choices:
- Lens effects and denoiser settings have 2 on/off buttons. The "eye" icon in the layers seems to only effect the rgb colour pass as when turned on in their individual settings (enable...) they are on in the effectsresults pass anyway.
- When saving out the passes (save all images to separate...) the exposure setting is ignored for the rgb colour pass. Is this correct? Surely if this is set to on, and following the logic that the "eye" icon means it effects the rgb colour pass, then it should save it with the exposure settings.
Personally I would prefer an option to be able to save the denoiser and lens effects as separate passes (so a effectsresult-denoised.tif and a effectresult-lens effects.tif). Now I'm just saving 3 times instead of the 2. But that might just be me.
V-Ray Next:
