NAN pixels with extreme values creating bright lens flares
  • NAN pixels with extreme values creating bright lens flares
    I've got a scene which has an extremely bright pixel that I'm not sure where it comes from. It creates an extremely bright lens flare when I turn on the lens effects. When I put my cursor on it, it says "nan" instead of reading a float value. What is this and how do I get rid of it?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 566.14
    Could you send the scene to milva.perkovich@chaosgroup.com so we can take a look?
    Milva
    Milva Perkovich
    QA department
    Chaos Group
      Hi, Milva. I've just sent you an email containing download link for the scene.
      Aleksandar Mitov
      96GB DDR5
        "NaN" means "Not a Number".
        I.e. the value in that pixel is out of bounds of the precision on offer, or due to incompatibilities or bugs (say, odd normal map...), it's literally not representable as a color.
        There are cheap ways in post to deal with this, but it's generally much better to find the source of the issue in the scene to be rendered.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          I think I found the culprit! The glass material on the sliding door had Fog Bias amount of -10. I set it to 0 and the bright pixel was gone.
          Aleksandar Mitov
          96GB DDR5
            aaaah, great find!
            Please do send the offending bits to support!
            EDIT nevermind me. never saw your previous post.
            Lele
            Disclaimer:
              Hi Alex,
              Thank you for the scene and the information, they were very useful for the problem identification.
              This bug is now logged in our internal bug-tracking system (VMAX-10305).
              In addition: enabling "Calculate Denoiser" option resolves the problem with the overbright Lens Effects. You can use this as a workaround in case you want to keep the Fog bias values unchanged.
              Milva
              Milva Perkovich
              QA department
              Chaos Group
                Thanks, Milva.
                Aleksandar Mitov
                96GB DDR5
