Shadow flicker
  • Shadow flicker
    I have problems with strongly flickering shadows.
    max 2021, V-Ray 5
    - maxstart.max deleted
    - after restart of max switched from arnold to vray
    V-Ray Settings:
    Default, Buckets, LC-Preset Animation
    Result:
    KaFa_max2021_Vray5_DefaultSettings.mp4
    Loop6Frames_DomeL_Tex_BFLC_VRayDeflault.mp4
    I only get good result with local subdivision (V-Ray4, Global DMC).
    Result:
    KaFa_max2019_Vray4_DMC-LocalSubDiv.mp4
    Loop6Frames_DomeL_Tex_BFLC_localSubDiv.mp4
    MP4-Files in "Flicker_mp4.zip"
    Could you send the scene to support@chaosgroup.com so we can take a look? Mention this thread in the e-mail along with your V-Ray, host platform versions, and a log from the rendering.
      did you find a solution to this?
        No scene was sent for investigation, I'm afraid. If you have a similar issue, do write to the mentioned address with the necessary information.
          Was there any conclusion, I have the same problem. Thanks!
          CPU: 5930K
          GPU: 3x970 GTX,
          MEM: 32 GB ram
          SSD
            Without a scene, we can't figure things out: they may be obvious to some, but they aren't always so to us.
            It'd be good if you could send one to support.
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
              I cannot really send you the project files. Here is the problem: https://www.dropbox.com/s/f8986qfffr...RGB_1.mp4?dl=0
              Light cache, gpu render with 3 gpus. vray default denoiser, its not turned on in this video, but produces the same flickering
              CPU: 5930K
              GPU: 3x970 GTX,
              MEM: 32 GB ram
              SSD
                looks like light cache to me. try bf+bf first.
                Marcin Piotrowski
                youtube
                  GPU-calculated LC?
                  That's still very WIP.
                  Try the CPU LC if you haven't yet, it ought to fix the kind of issue you see.
                  Lele
                  Disclaimer:
