Vray camera Tilt & Shift weird behavior
  • Vray camera Tilt & Shift weird behavior
    i'm using vray physical camera tilt & shift.
    shifting the composition horizontally behave strangely (in my opinion).
    shifting shouldn't change the perspective of objects in the composition neither should distort objects... (https://www.youtube.com/watch?v=gvV5...&index=17&t=0s)
    this is what's happening in my scene : https://www.screencast.com/t/Sc4UrYALY
    what i'm I missing?
    i'm using V-Ray 5, hotfix 2 (5.00.05 build 000001) on 3dsmax 2021.
    thanks!
    Guillaume
    When you shift to the end of the frame, the image is more distorted when using a wide angle lens. It will be the same without the sift if you use a larger image sensor and the same lens.
    If you use a less wider lens you will have less distortion. You can position the camera backwards, enable the camera clipping (in case there is no room), and you will have the same filed of view with less distortion.
    http://ftp.chaosgroup.com/support/sc...9_11-48-28.jpg
    Martin Minev | chaos.com
