embree errors
  • embree errors
    I have opened the scene (vray next) and I was trying to render it with vray 5, but I am having getting embree error (attached). All good if I switch off the displacement. The thing is that it was rendering fine on my older rig with 64Gb and this machine has 128 gb so it should not be and issue. When I switch the embree off, vray renders only forest pack objects and proxies... I have tried to reset the settings, switched between rendering types, so maybe merging into new scene would help, but I would rather would like skip those solutions. Anyway as I mentioned switching off displacement helps so I wonder if something has changed under the hood from next to 5.
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
    Any help with this guys? Merging into new scenes did not help.
    Best Regards
    Tomek
      Hi urbanite,
      Can you please forward this scene to support@chaosgroup.com for further investigation? Make sure to mention this forum thread in the email, thanks.
      Nikoleta Garkova | chaos.com
        Thanks but I manage to make it work. I recreated all vray displacement modifiers and that did the trick.
        Best Regards
        Tomek
