Value changes depending on the size of VRayLightMeter
  • Value changes depending on the size of VRayLightMeter
    Why does the value at the same point change so much when I change the size of VRayLightMeter (Width and Length parameters)?
    Tested with V-Ray Next upd3.2 and V-Ray 5 VRayLight Meter.
    Attach a simple scene
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Thank you for the feedback. We will look into it.
    Milva
    Milva Perkovich
    QA department
    Chaos Group
      I look forward to an early solution.
      oakcorp.net
      v-ray.jp
        Is there a way to match the results? Or is it a bug?
        I cannot confirm the reliability of VRayLightMeter.
        oakcorp.net
        v-ray.jp
          The problem here is that VRayLightMeter is placed in a closed geometry with no light source in it and in this case it is not expected to work at all. The reason it shows any values different than zero is that it probably detects leaks in the light cache.
          If you move the VRayLightMeter helpers up, so they are outside of the boxes you will see accurate results.
          Can you give us more info about what do you want to achive, so we can try to find a solution for you
          Milva
          Milva Perkovich
          QA department
          Chaos Group
            I received the scene data in question from a customer. I'll send it to support@chaosgroup.com, so let's talk about it there.
            oakcorp.net
            v-ray.jp
              No response from Chaos Group?
              ticket number is: 318-177-5866 
              oakcorp.net
              v-ray.jp
                I haven't heard back until today. My customer is waiting for an answer.
                oakcorp.net
                v-ray.jp
                  Hello, ChaosGroup Support
                  Is the support department working?
                  oakcorp.net
                  v-ray.jp
                    Hi flat
                    Apologies for the delay in our reply and thank you for sharing the scene to support. We will review and reply back to you ASAP. Thanks for your understanding!
                    Nikoleta Garkova | chaos.com
                      Is it possible to control the sampling accuracy of VRayLightMeter to stabilize the result of VRayLightMeter?
                      Raising the LightCache Sdiv has no effect on VRayLightMeter.
                      oakcorp.net
                      v-ray.jp
                        Currently, VRayLightMeter's values are not calculated per point but are based on an approximation in every division/segment of the light meter itself. This is causing the differences in the output numbers, however, they shouldn't be that large. We've logged this in our system for developer investigation (internal ID number: 10395) and we will let you know when we find a solution to stabilize the results. Thanks for pointing that out!
                          thank you for answer.
                          I will tell the customer this answer.
                          oakcorp.net
                          v-ray.jp
