I'm getting problems and crashes when I use Nvidia denoiser with a couple of Threadripper 1950x render slaves. I'm not sure if it's related to the problem, but both render slaves have very basic GPUs - Nvidia 210 512 mb which are just for display output and nothing fancy. Could the problem be related to this?
Here are the issues in more detail:
Issue 1: When rendering with the 1950x slaves with Nvidia denoiser turned on and using the bucket sampler, Vray doesn't construct the Nvidia denoiser's channels properly which leads to improperly denoised image after the rendering is finished. Please check the screenshot below. All buckets with pure purple color are the Threadripper 1950x slaves.
![Click image for larger version Name: vfb1.png Views: 1 Size: 328.0 KB ID: 1087261](filedata/fetch?id=1087261&d=1603919548&type=thumb)
Issue 2: When rendering with the 1950x slaves with Nvidia denoiser turned on and using the the progressive sampler, Vray crashes right away. I have the 3dsmax minidump file of the crash if you need it.
Both issues happen in every scene I've tested so far so I don't think that the problem is related to the contents of the particular 3ds max file. Also, there are no crashes if I use a Threadripper 3970x machine as a DR slave, but I should also point out that this machine also has a different GPU - Nvidia GTX 980.
Software used: Max 2021.2 + Vray nightly 5 (5.00.30 build 30324)
