Hi All
As per the title when trying to deploy Vray 5 (either a workstation or render node build where appropriate) for a particular version of Max it is removing Vray 5 for the other version of Max. This doesn't happen if I manually run advanced installs locally, but with 30 workstations and 12 render nodes to update I of course would prefer not to have do this manually. I've tried changing the SHOULDUNINSTALL value to 0 instead of the default 1, but this doesn't seem to make a difference. I wouldn't expect this to anyway as I assume it's Vray for Max version specific, but just trying to rule things out.
I've triple checked the xml configuration files etc and can't see anything amiss. I've been deploying multiple versions in this way since vray 3.6 and this has not been an issue before. We use EMCO remote installer to do this. Command line to deploy the software is below:
"\\HD-FS1\Data\operations\ARTIST\IT\APPROVED SOFTWARE\ChaosGroup\Vray\2020\vray_adv_50005_max20 20_x64.exe" -gui=0 -configFile="\\hd-fs1\Data\operations\ARTIST\IT\APPROVED SOFTWARE\ChaosGroup\Vray\2020\config_2020_node.xml " -quiet=1
"\\HD-FS1\Data\operations\ARTIST\IT\APPROVED SOFTWARE\ChaosGroup\Vray\2021\vray_adv_50005_max20 21_x64.exe" -gui=0 -configFile="\\hd-fs1\Data\operations\ARTIST\IT\APPROVED SOFTWARE\ChaosGroup\Vray\2021\config_vray_5_2021_r endernode.xml" -quiet=1
I've attached the xml files as referenced above.
Any help on resolving this would be greatly appreciated!
Thanks
Dan
Thanks
Dan
