GPU usage when rendering with CPU ?
  • GPU usage when rendering with CPU ?
    Hello,
    noticed something strange (?). I launched a rendering using DR CPU, as usual, and i noticed that the GPU (rtx3090) was at 15-20%, even if i did nothing special, just watching the Task Manager.
    When the CPU rendering was finished, the GPU came back at 1-2%
    Is this normal ? What's going on when with the GPU when rendering on CPU ?
    Thanks!
    Could be some hardware accelerated VFB effects?
      Lens Effects aren't enabled in the rendering
      tested on another workstation, same result with 15-20% of GPU usage when rendering (1080ti)
        muoto do you have Denoiser enabled? If Post Effects Rate is set to update frequently, then 15-20% of GPU usage during rendering should be normal. Are you testing with the same scene?
        Nikoleta Garkova | chaos.com
          Nope, no denoiser, same scene, same two workstation just 2 different video cards (1080ti and 3090), same max, same vray
            Could you share a piece of the scene which shows the behaviour with Support, then?
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
              OK, i have just done it!
                Thank you!
                Lele
                Disclaimer:
