Using VRay 5 hot fix 2 and am having a strange problem with one scene. Also using Max 2021, though am potentially switching back to 2020 due to the endless problems I have with it and a loss of performance in the viewport, but that's another issue.
I have a simple daylight system and VRay Sky in the environment override slot but the sun will not light the scene even though it says it's active. Weird thing is if I start IPR there's no sunlight but if I hide the sun or the layer that it's in then suddenly the sun is active again. If I start the render again, same thing happens and production has no sunlight at all.
This doesn't happen in any other scene and have tried to merge everything into a new file with the same result. Also removed the sun and set up a new daylight system, same story.
Any ideas what could be happening? I'm stumped.
