Vray displacement depends on Camera lenses
  • Vray displacement depends on Camera lenses
    Hi guys,
    I have strange problems with my scene.
    I'm using Vray NEXT 3.2
    In the scene in which I'm rendering everything working perfectly fine if I'm rendering thru physical cam with the lens of Focal Length 25, but as soon as I'm changing lenses value to something higher, like in my case Focal Length 200, my scene will not render anymore.
    As far I understand, the problem is displacement. If I'm switching displacement off, my render with the same camera settings is perfectly fine.
    Anyone any solutions or similar problems??
    Change edge lenght if you're expressing it in pixels (making it a bigger value), or set the displacement to use world units, and make the edge length what value it is you need, and that won't change based on what the camera sees or the resolution is.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
