GetOcioPath() ?
  • GetOcioPath() ?
    Hey guys!
    Is there any way to get the OCIO file Path in the VFB?
    I'm looking for a way to know if there is any path written here.
    Thanks!
    Not sure what you mean. If you've loaded an OCIO config in the designated slot it will appear there; this includes the case where the configuration is loaded via an environment variable. Nothing is loaded in the attached screencap.
      I want to get the OCIO config path, easy.
      Ofc in the attached screencap that would return "" because it's empty. It was just to show you what I'm trying to get.
        here! I need to get the string "c:\My_Awesome_path\ocio.config" in maxscript
          Ah. This should do it:
          Code:
          vfbcontrol #ociofile
            Great! it works perfectly thanks
