Rendering Point Clouds as 360 Panoramas
  • Rendering Point Clouds as 360 Panoramas
    I've been working with a lot of point cloud data recently and so far everything has been working fine.
    One of the outputs our engineers like is a virtual tour made from rendered images of the point clouds (like google street view) We also use this to create tours from 'normal' geometry as well.
    To do this I position a camera in the scene and in the Cameras section of the Render set up select 'Spherical Panorama', override the FOV to 360 and the Vertical FOV to 180. This gives me a perfect panoramic image to load into our virtual tour software.
    However this dosn't work for point clouds and I get a very small mass of points in the centre of the rendered image (if there is any normal geometry in the scene it renders OK).
    If I change the angle on the FOV I can get it to work. It will render at 120x180 degree view but nothing bigger. So my workaround to to use 3 cameras and then join them together afterwards. this isn't a big issue with one view but the last one had 30 panoramas so it would be good to have it render in one go.
    I'm using Max 2021 and Vray 5
    - Garry
    Garry Clarke
    Technical Illustrator
    www.garryclarke.com
    I've just installed VRay 5.1 and it's fixed - Yay!
    thanks, and the other additions look good too.
    Garry Clarke
    www.garryclarke.com
      Hi Garry,
      I am just wondering what your process for rendering a 360 point cloud is, as I seem to be running into trouble doing it myself.
      I've rendered plenty of 360 images out in the past using the same technique as you (Camera type set to Spherical Panorama, FOV set to 360 & 180) but end up with a blank screen when trying it with a point cloud. The point cloud renders fine if I leave the camera at the default values, just blank when I try to render a 360.
      Like yourself, I'm using Max 2021 but with Vray 5.2. I had this problem with 5 and 5.1, so it can't be an issue with the current version.
      Any insight would be greatly appreciated, as this is driving me nuts!
      All the best,
      Andy
      Andy Davenport
      3D Animator|Compositor|VFX Artist
      Glitch VFX Ltd
      www.glitchvfx.com
        Hi Andy,
        Just noticed this message (I don't check in here very often) did you get your point cloud problem sorted out?
        -Garry
        Garry Clarke
        www.garryclarke.com
