Vray 5.1 Camera tilt shift+IPR issue
  • Vray 5.1 Camera tilt shift+IPR issue
    Hello,
    There is an issue using the IPR with tilt shift on vray camera. See attached
    Same problem here.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Yep, just noticed this as well too.
        Try change the Horizontal Shift to 0.00
        Jackie Teh
        3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
        Website: https://www.sporadicstudio.com
        Email: info@sporadicstudio.com
        YouTube: https://www.youtube.com/c/SporadicStudio
          3ds max 2021 v-ray 5.1 IPR give vertical distortion after changing viewport. unable to use this update without this fix.
            As I had this issue too in 2019 with VRay Next I tested it now with 2021 and VRay5 Hotfix2. In my configuration automatic and manual vertikal tilt works fine. But when I use shift I have the same problem. If I remember correctly in 2019 it was only the IPR that doesnt match the viewport. But the final render was fine. Now the final render matches the IPR, not the viewport. This is really not usable....
            Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
              Hi guys, thanks for pointing that out. It's been reported under VMAX-10803 and our devs will have a look asap. We'll make sure to keep you updated. For now it appears that stopping and starting again the IPR will match the viewport.
              Nikoleta Garkova | chaos.com
                I have got the same problem with vray 5.1 and max 2019/2021. Fov and and shift very different between 3ds max viewport and the IPR window.
                  Hi again all,
                  We improved the release thanks to your quick feedback!
                  You can re-download the new V-Ray 5 Update 1 installations from our Chaos download page now, the IPR issue should be fixed - do share your feedback.
                  Please accept our apologies for the inconvenience! Many thanks!
                    It seems to be working fine now. Thanks!
                    Aleksandar Mitov
                    96GB DDR5
                      Yes, the new V-Ray 5, update 1 (5.10.00 build 00003) fixed the issue here
                      Jackie Teh
