VIZ 2006 - missing DLL w/ EGZ mats
  • VIZ 2006 - missing DLL w/ EGZ mats
    I'm able to install the EGZ beta materials like normal, and can create the materials just fine. But when I shut down Viz and re-open the same file, it says its missing the .dll for the materials even though its still there. Then when the file opens the material does not work, but it will still let you create new EGZ mats.
    I'm sure its not a Vray bug, or EGZ bug, but has anybody else had the same problem with VIZ 2006 and found a solution yet?
    Tim Nelson
    timnelson3d.com
    I have the same pbl with max but Eggz run if you not click OK.
    perhaps Eggz could have the solution.
    Laurent
      Ahh, I will have to try that next time.
      It's strange it didn't happen with Viz 2005.
      Tim Nelson
      timnelson3d.com
        My pbl was coming after I had start 2 3dsmax in the same time and shotdown one of these.
        Very strange
        Laurent
          This sounds very strange.. I don't have VIZ so I can't check if they work as intended in Viz 2006. Does this happen all the time? Is VRay assigned as renderer when it happens? Do you start Viz by doubleclicking the file, or do you start Viz, and then open the file?
          priad: Which max version are you using?
          Torgeir Holm | www.netronfilm.com
            max 7
            Laurent
              with service pack 1?
              How did you install the materials? Make sure you don't have the mzp file itself located in the max plugin or script path.
                thanks Egz
                service pack 1
                I haven't mzp file in path.
                my error is just for eggz light.
                But it work. thi is just a warning.
                Laurent
