I've got this image sequence that doesn't appear to be including the filmic tomemap layer into either .jpg or .png output sequence - specified through the frame buffer tab. Fyi, I had the blending weight in the VFB set at .35 when the sequence ran.
Is this because of something I've not setup correctly? Thanks in advance for any solution.... Rendered through CPU
