Vraydistancetex and Tyflow working on main machine but not on render nodes
  • Vraydistancetex and Tyflow working on main machine but not on render nodes
    I have tyflow particles setup on my main workstation and the results are fine, as expected but when I try to render on my nodes, including turning my main workstation into a render node the results are incorrect. Is there an issue with Tyflow and vraydistance tex?
    Regards
    Steve
    My Portfolio
    I presume you're using the TyFlow system as a VRayDistanceTex object, correct? I tested rendering with DR and Deadline but everything seems to be in order. How are you sending them to the nodes? Make sure the TyFlow plugin is installed on the nodes as well.
      I'm basically just using Backburner. The same version of Tyflow is installed on all nodes. I don't have issues with any other aspects of Tyflow apart from when using Vraydistancetex in combination with it.
      Regards
      Steve
      My Portfolio
        Seems to work fine on Backburner as well. Maybe you could send the problematic file (simplified if possible) via the contact form so we can take a look? Also, which V-Ray are you utilizing?
