This whole thread is extremely confusing. I do not think these problems are related to one another at all.
Isolate Selection
But they are. I removed the displacement shift and no more crashes. I put it back on, render, and it crashes and doesn't open again with the same isolation stuck screen.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
I spoke too soon. It still crashed and wouldn't open with the isolated message. I removed the displacement altogether with and it is rendering now. Thankfully, with this material at this distance, I don't really need the displacement. For the record, I rendered, closed MAX, and opened it again just fine.Bobby Parker
phone: 2188206812
- Windows 11 Pro
It does sound like it isn't connected but then there seems to be a connection somehow...so a bit of a paradox...unless...
Just a wild thought; The thing that you are rendering, which is isolated, has displacement on it that 'may' be causing the error - so could it be that that displacement is
referencing something that is 'not' isolated and so causing some weird loop....something along those lines..
It's hard trying solve these things without any actual scene to investigate, so maybe it'll remain a mystery
The isolation thing makes no sense anyway. There isn't anything isolated and every MAX file I open has it. I reported that to AD many times, but I never got any replies. I'll record something when I have time.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Aah I see....so it's literally every file you open triggers that popup....no connection to displacement then lol.
Given that there is no text or button I reckon it's a conflict, or a tear in the the Matrix
...just do a reinstall of Max after deleting all the leftover stuff.
At least then you can install whatever plugs/scripts you use, one by one, testing until you hopefully find the culprit that is causing
the conflict.
Originally posted by fixeighted View Post...just do a reinstall of Max......
........ then you can install whatever plugs/scripts you use, one by one, testing until you hopefully find the culprit that is causing
the conflict.
Jez
3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
---- Updated 06/09/23 -------
Maybe recreating a new ENU folder might be worth a go firstJez
MAX should be updated next month anyway, so I think I'll just wait.Bobby Parker
phone: 2188206812
- Windows 11 Pro
