Phsyical camera tilt correct ignored in IPR.
  • Phsyical camera tilt correct ignored in IPR.
    When using the standard physical camera, tilt correction works when the IPR is first started but then is ignored whenever a change is made interactively. The render has to be stopped and started again.
    This issue should be hotfixed, try downloading and re-installing V-Ray.
      thank you!
