3ds Max Freezes after opening material editor.
  • 3ds Max Freezes after opening material editor.
    Hello,
    I am writting regarding an error I am actually facing in two different machines, I got installed the latest 3Ds max 2021 and the latest V-Ray version, everything works ok until I open the material editor, then Max doesn't crash, but suddently is like 50% responding, keyboard doesnt respond on 3Ds Max, and some buttons freezes. I can't find any crash log because 3Ds Max doesn't actually crash, but is not working. Anyone who had experienced the same got any solution? Thanks in advance.
    Hi fc_tirado
    Could you try resetting your 3ds max settings to their defaults.
    To do that you have to rename the ENU folder, which is located in the following place:
    • C:\Users\<username>\AppData\Local\Autodesk\3dsMax\ 2021 - 64bit\ENU
    Rename the ENU folder to ENU_old. When 3ds max is launched, a new ENU folder will be created. Keep in mind that this will remove any customizations you might have set.
    Nikoleta Garkova | chaos.com
      Thank you very much Nikoleta, it solved the issue
        Thanks for the update - glad to hear. Do let us know if you encounter any other issues.
