problem iniciate render IPR
  • problem iniciate render IPR
Name:	Captura de pantalla 2021-04-01 100329.jpg
    I'm having problems with vray
    when I start rendering, it takes 10s to start and when I start IPR I get the capture error and 3d max closes.
    only happens in max 2021 and vray 5.10.0 and vray 5.10.1.
    i have installed max 2022 and i don't have this problem.
      For starters, try resetting your 3ds max preferences to their defaults by renaming the ENU folder to ENU_old (C:\Users\<username>\AppData\Local\Autodesk\3dsMax \2021 - 64bit). Upon starting 3ds max, a new ENU folder will be created with the default preferences. Note that this would remove any customizations you might have set.
        That solved the problem, maybe a script had a problem with vray.
