VRay ZDepth - Colored alpha edge and NaN pixels
  • VRay ZDepth - Colored alpha edge and NaN pixels
    Hi all,
    We are experiencing an issue with the VRay ZDepth pass. The following is observed:
    1. Using the bucket image sampler
    • Dots of pixels indicating the buckets forming a pattern with NaN pixels
    • Colored matte edge of objects (looks like chromatic abberation).
    2. Using the progressive image sampler
    • No NaN pixels with this sampler, but the colored matte edge is still visible.
    Problem occuring both when rendering locally and on render nodes without the VRay frame buffer enabled. Rendering with the VRay frame buffer locally, the error is not visible. Tried saving in different file formats and depths, same results. All other passes renders normal.
    Experiencing this issue with VRay 5 update 1.1, clean install on new 3ds Max 2021.3 install.
    Anyone recognize this type of error? All help is greatly appreciated.
    Update:
    As part of a major pipeline overhaul, we went from V-Ray 3.6 straight to V-Ray 5 update 1.1. I have now tested reverting back to earlier releases of V-Ray on two of the render nodes, the following is observed:
    • VRay 5 update 1.1 - Problem occurs as initially described in post above
    • VRay 5 update 1 - Problem persistent
    • VRay 5 hotfix 2 - Problem gone
    So may be a problem with the recent V-Ray release, or a more puzzling problem on our end...
      Hi ramschaft
      Would it be possible to forward a stripped version of the scene with the issue reproducible so we can have a look on our end?
      You can send it via our contact form, just make sure to mention this thread in the email. Thanks!
      Nikoleta Garkova | chaos.com
        Hi nikoleta.garkova
        Thanks for your reply. I have now sent an email to support.
          Hi ramschaft
          Thank you for providing the files over. I can confirm this is reproducible and it is now logged under VMAX-11005.
          Unfortunately, the only workaround for now appears to be rendering with the VFB enabled.
          I will make sure to let you know when there are any updates on the matter. Thanks for pointing it out!
            Just ran into this same issue and was about to post when I found this thread. Any news on the matter?
            http://henrikbclausen.com
              Hello,
              We have it fixed in our internal builds and it should get to the public nightlies soon.
              Yavor
              Yavor Rubenov
              V-Ray for 3ds Max developer
                Originally posted by yavor.rubenov View Post
                Hello,
                Yavor
                Nice - thanks!
                  Any updates on this issue? We are still having the problem with 3dsmax Vray 5.10.02.
                    It is fixed in the stable nightlies (for example here: https://nightlies.chaosgroup.com/mai...e_5.1/20210604).
                    Yavor Rubenov
